R12.1-2025July30
View Task Results
API Triggered Tasks contain all API call task instances and relevant information from the integrated third-party systems. The system generates an API task instance for every incoming API call.
- Log in to the NetBrain system.
- Click the start menu, and select Map-Based Automation > Runbook-Based Triggered Automation.
- Click the API Triggered Tasks tab. All triggered tasks are listed.
- Click the map hyperlink of the triggered task to view the created map as well as the data collected by the runbook (as long as you have added a runbook when defining the task).
