R12.1-2025July30
Visualize Meraki Network by MERAKI Devices
Meraki devices are classified into Meraki MX, Meraki AP, Meraki switch, and Meraki Z3 devices.
Follow the steps to view the details of a node.
  1. In the NetBrain desktop sidebar, open Network
  2. In the Network pane, select MERAKI in the Category field.
  3. In the View field, select MERAKI Devices.
  4. Expand the MERAKI Devices node to view more information.
    Information Tip: The number next to each node indicates the number of its child nodes.
  1. Select a node and click the Device Details pane to view the node’s detailed properties, interface and IP interfaces.
    Graphical user interface, text, applicationDescription automatically generated
