Use Task Variable in PDAS-NG
After the task variables are selected for use in the intent, they can be used to transfer values. Task variables can be supported in the following features using NIT throughout PDAS-NG:
| Features | Description |
| TAF - Trigger NIT/ADT Intents/NIC/Intent |
| Auto Intent |
| Bot |
| Follow-up NIT/Intent/Self/ADT Intents |
