R12.1-2025July30
Use Prompt Node
You can leverage the prompt node to organize bot conversation flow by grouping automations.
- Drag and drop the prompt node to the flowchart.
- Double-click the node to rename it.
Power User in Editor | End User in Chat Console |
Example: To execute the L2 General Check intent, End User: Click Daily Check > L2 General Check |
