Sync Up Playbook from SCM
Information Note: Git Client must be installed on Ansible Agent Server before using any SCM functions. See more details in Installing NetBrain Ansible Agent on Linux.
  1. Click the Manually Defined dropdown selector and select an SCM Manager from the list.
  2. Graphical user interface, application, Word
  3. Click Sync to retrieve the latest version file from SCM. You can enter Branch/Tag/Commit to search the related playbooks.
  4. Graphical user interface, application
    Information Tip: See SCM Manager for more details to add a new SCM.
    Information Tip: Branch, tag, or commit number is for retrieving a specific revision file.
  5. Select a playbook (in .yml or .yaml format) from the dropdown list.
