Search for Automation Assets
You can search for automation assets, such as Qapp, Runbook Templates, and Data View Template in the Search bar. All the matched Intent, Qapp, Runbook Template, and Data View Template will be centrally displayed in the search results pane.
Example image:
Information Note: The NetBrain System supports fuzzy search of automation assets.
The following table lists the properties supported for the Automation Assets search:
Table 1 - Properties for Searching Automation Assets
Automation Assets Search by name Search with description Search with tag Search with ID
Qapp
Runbook Template (RBT)
Data View Template (DVT)
