Runbook Template to Document Network Know-How
As Network Tasks are executed on a Dynamic Map, the Runbook is automatically populated with nodes and results that can be accessed by any other engineer, which enables them to share maps that contain the exact steps performed by previous engineers, reducing duplication of efforts, and creating a sharper focus to the nature of the problem.
In addition, once users create runbooks for specific processes, they can save those runbooks as Runbook Templates as recommended actions to share their expertise with other engineers and departments, empowering junior operators to work more independently. In this sense, NetBrain helps make knowledge executable by encoding employee expertise into shareable documents that anyone can rerun on any network.
NetBrain provides sample and built-in Runbook Templates for some common technologies and troubleshooting processes.
Graphical user interface, application, websiteDescription automatically generated
Runbook Template can be set to be the recommended actions of a DVT, can be triggered to run by the API stub, and as part of the self-services of Intent-based automation flow.
