Reset Password
If you forget your password when logging in to your domain, do the following:
- Click Forgot password on the end user login page. The Password Assistance page opens.
- Enter your username or email address, and then click Submit.
- Check your Email Inbox and click the link provided in the mail from the system.
- Set your new password and confirm. Then click Submit.
Note: If you are not authorized to reset the password by yourself, contact your NetBrain administrator.
