Recreate a Site Map
When any customer's site map has changed the layout or if it is missing any links. Netbrain needs to generate a recreate the site map according to the new site structure and overwrite the old site map as follows:
  1. Click Site on the taskbar to open the Site pane.
  2. Expand the site tree, open the drop down menu of the target site and select Recreate Site Map.
  3. Click Yes to confirm on the Confirmation prompt.
  4. Modify the map as per the hierarchy changes and click  on the map to save and close the changes.
See Map Editing Rights for more details.
