R12.1-2025July30
Quick Intent
Quick Intent is a function that enables power users to create intents by defining simple diagnosis based on the current map devices.
  1. Collect Data: Select target devices and enter commands to retrieve device data.
  2. Apply Parser: Directly select a parser or new a parser to parse the retrieved data.
  3. Define Logic: Define diagnosis to detect the changes.
  4. Target Device: Select the target devices and duplicate the current diagnosis to these devices.
  5. Preview Intent: Preview and execute the intent to view the execution result on the map.
