Only Map Device with Alert or Success Status Code
  1. Enter the NI Edit Mode, then click the  icon and select Intent Settings.
  2. On the Map Settings tab, only select the Success check box in the Display Output Map on Base Map area.
  3. Click OK. Then save the intent.
  4. Click Output Map to open the intent result on the map, and you will see that only the devices with successful status code are displayed.
