Multi-Vendor Support List (SDN)
The table below describes the SDN (including SD-WAN) device types and vendors supported in the system:
TechnologyDevice Type Supported LevelDiscovered via
Tier 1Tier 2Tier 3
SDN-WANCloudGenix ION SD-WAN CLI/API
VeloCloud Edge SNMP/CLI
VeloCloud Gateway SNMP/CLI
VeloCloud Orchestrator  SNMP
Versa Analytics CLI
Versa Controller API
Versa Director CLI
Versa FlexVNF API
Viptela vBond API
Viptela vEdge SNMP/CLI
Viptela vManage API
Viptela vSmart API
 Cisco Meraki Z3  API
 Cisco MX   API
 Aryaka router SNMP
Cisco ACICisco ACI APIC API
Cisco ACI Leaf Switch API
Cisco ACI Spine Switch API
EXSiVM Host API
vSphere Distributed Switch API
vSphere Standard Switch API
VM NSX-V (for vSphere)NSX Manager API
NSX Controller API
NSX Logical Switch API
NSX Edge Security Gateway API
NSX Distributed Logical Router API
AVIAVI Controller  API
AVI Service Engine  API
Big Switch Big Switch Controller SNMP/CLI/API
Big Switch Spine Switch  API
 Big Switch Leaf Switch  API
The limitations of SDN support include the following:
      • Cisco ACI
        • Remote Leaf is not supported.
        • Cannot map out EoMPLS devices between Transit Leaf and Spine for Stretched Fabric deployment that uses EoMPLS to interconnect Transit Leaf and Spine.
        • Running Qapps on logic nodes (like Tenant, VRF, EPG, etc.) is not supported.
      • NSX-V
        • Overlay L2 topology and underlay paths are not supported.
      • Big Switch
        • Only support spine/leaf switches' L2 link(NDP) table. Other data is retrieved from the controller as NCT tables.
      • Cisco Meraki Z3 and MX
        • SD-WAN routing table is populated by NetBrain's algorithm but not exported by API.
        • The netmask of some interfaces cannot be accurately retrieved by API. However,  the netmask of the VLAN interface can be retrieved by API.
