Migrate Data for Front Server
The monitoring variable and timer probe related data are stored in Front Server. When the Front Server/Front Server Group setting changes in a device’s Shared Device Setting, you need to migrate the data to the new Front Server/Front Server Group to ensure the data for the timer probe and monitoring variable is complete.
Note: Front Server must be connected to the Front Server Controller during the data migration task. |
Follow the steps to migrate the data to the new Front Server.
- Log in to Domain Management Page.
- In the Domain Management page, select Data Accuracy Resolution from the start page.
- Select Data Migration Tasks from the Data Accuracy Resolution page. You can view all the Front Server changes listed in this page.
- You can click on Migrate All to migrate all the data for Front Servers; or you can select a specific device from the list and click on Start to migrate the data for individual devices.
- You can export the table as .CSV file by clicking on
on the top right corner. - After the data migration has finished, you can right click on the selected device and select View Log from the drop-down menu to view the execution logs.
Note: Domain Management privilege is required to access the Data Migration Tasks table; Front Server data migration privilege is required to migrate the data for Front Server.
