Manage the Integrated IT System
  2. Click the start menu and select Integrated IT Systems.
  3. To manage the integrated IT system, select the entry and click , you can:
  • Edit the integrated IT system
  • Delete the integrated IT system
  • Export the integrated IT system: The entry will be exported to a local file named <Integrated IT system name>.xits.
    Information Information Tip: To export all entries, click. The system will create a local zip file.
  1. To import Integrated IT systems from a file, click Import > select a local file.
