Live Access
You can specify various settings for live access, including timeout values, SNMP hostname trimming, and more.
Field/Check Box | Default Value | Description | |||
Timeout
CLI Connection Timeout
10 seconds
The timeout value that defines the maximum time for the system to attempt to establish a CLI connection. That is, for how long the client will try to establish a network connection via SSH or Telnet.
CLI Session Timeout
30 seconds
The timeout value that defines the maximum time for a CLI session to last if there is not any response from the device.
CLI Force Timeout
600 seconds
The timeout value that defines the maximum time for a CLI request to retrieve a command. That is, the maximum time for the Front Server to retrieve route/ARP/MAC tables, configuration files, and other data by Telnet/SSH. If your network is unstable or slow, configure a larger number.
SNMP Session Timeout
2 seconds
The timeout value that defines the maximum time for a SNMP request to get a reply. That is, the maximum time for the Front Server to monitor, discover live paths, retrieve ARP/MAC tables, and obtain interface indexes by SNMP. If your network is unstable or slow, configure a larger number.
SNMP Hostname
Trim all strings after dot in SNMP hostname (default)
Enabled
Trim all strings after the first dot in an SNMP hostname and use the remaining strings as the hostname in the system. For example, if the original SNMP hostname is "router.netbrain.tech.com", it will be parsed into "router". |
Trim following domain names from SNMP hostname
Disabled
Trim the specified domain names from an SNMP hostname. For example, if you enter the ".tech.com" string as input, the "router.netbrain.tech.com" string will be parsed into "router.netbrain".
Management Interface Selection Order
management;loopback;vlan;ve;ethernet
The order of interface types used to set the management interface of a device. When the system retrieves live data for a device, it accesses the device through its management IP address in the Shared Device Settings. In the tuning live access process, the system can reset the management IP address by following the management interface selection order.
Discovery and Scan
Continue to discover, if the IP to be discovered is not duplicated with the existing device management IP. (Used for the situation that device management IP has a duplicate with other devices' interface IP.)
Disabled
Enable the option when the device management IP has a duplicate with other devices Interface IP.
Auto add MPLS PE IP to Do-not-Scan IP list
Enabled |
When enabled, this option automatically adds the Provider Edge (PE) IP addresses from newly created MPLS Clouds to the "Do Not Scan" IP list.
These PE IPs are on the carrier’s side and are typically inaccessible through Live Access, so excluding them from scans helps avoid unnecessary scan attempts and improves performance. |
Benchmark |
Retrieve BGP / All VPNv4 Advertise Route Table on MPLS CE device only
Enabled |
When enabled, the system will:
This targeted retrieval method helps reduce benchmark time and avoids collecting unused BGP data. |
Polling Order
Trying to login device directly, then login via Jumpbox
Enabled
Attempt to directly log in to devices via Front Server first. If the direct login fails, then the Front Server will attempt to connect to the Jumpbox to log in to the device.
Trying to login device via Jumpbox, then login directly
Disabled
Attempt to log in to devices via Jumbox first and then attempt direct login through Front Server if the login via Jumpbox fails.
If ping fails, don't try Telnet/SSH in Tune Live Access and Seed Discovery
Enabled
Disable the use of Telnet/SSH access method in the tuning live access and seed discovery features when ping fails.
If ping fails, don't try SNMP/Telnet/SSH in Scan IP Range
Enabled
Disable the use of SNMP/Telnet/SSH access method to access a device in the scanning IP range feature when ping fails.
Third Party Telnet/SSH Tool
Enable Telnet/SSH CLI via third party tool
Disabled
Determine whether to call third-party Telnet/SSH tools in NetBrain systems.
SSH Fingerprint Check
Enable SSH Fingerprint Check and Auto Fill-in Fingerprint Key to the Devices
Disabled
Determine whether to use fingerprint for authentication when logging in to the device via SSH.
Note: Any changes to the settings will take effect from the next discovery and benchmark task. |
