R12.1-2025July30
Inventory Template (SDN Host Group)
Example: Inventory Template (SDN Host Group)
Replace the highlighted content with the specific parameters to customize your template.
global_variables:
    ansible_connection: local
host_groups:
    - name: CISCO_ACI # to be manually modified by user
      group_variables:
       descr: "Group CISCO ACI"
      hosts: # use NetBrain Intellisense Variables here to define SDN controllers as hosts
       - $sdn_controller.APIC_1
       - $sdn_controller.APIC_2
      host_variables:
       username: $credential.username
       password: $credential.password
The following table lists the description of the main parameters.
ParameterDescription
global_variables
The variables of Ansible default group “all”, which will be applied to all hosts.
Note: Global variables should be constants. NetBrain Intellisense Variables are not supported.
name
The name of the host group, which is auto-generated and defined from UI. See Define a Legacy Host Group for more details.
Note: Any unspecified host groups will be assigned to the default Ansible host group ungrouped.
group_variables
The variables of the host group. See Ansible group variables for more information.
hosts
The name of SDN Controller.
Note: Make sure to add a leading hyphen ‘-‘ when defining each host, as it indicates the following data structure is an array/list in YAML syntax.
host_variables
The variables of the host. See Ansible host variables for more information.
Note: Values of host variables need to match the host's GDR properties or interfaces.
Note: ‘$’ can be used to trigger NetBrain Intellisense Variables.
Example: Inventory Instance (SDN Host Group)
To suit your specific project needs, you can modify the existing or add new key/value pair(s) in the inventory instance. All sensitive data in the Inventory Instance is encrypted.
Information Note: Make sure to replace the entire string when modifying the encrypted string *value_encrypted_donot_change*.
[CISCO_ACI]
192.168.48.211 username=admin password=*value_encrypted_donot_change*
192.168.48.135 username=root password=*value_encrypted_donot_change*
[CISCO_ACI:vars]
descr="Group CISCO ACI"
