Install Splunk
For installation, the Splunk app can be found in this download link: https://www.netbraintech.com/docs/SplunkApp/netbrain_trigger.zip, and the password is Netbrain@2023. The first step in Splunk integration is installing the NetBrain Splunk app in the Splunk enterprise application. You can complete the following steps to install this application.
    1. Two different applications are provided, one for single-tenant deployment and another one for multi-tenant deployment. Download the required package based on the deployment in the system.
    2. Log in to the Splunk Enterprise and navigate to Manage Apps.
    3. Click Install app from file.
    4. Choose the application file you have downloaded above and click Upload. Make sure to click on upgrade app to check if the NetBrain Splunk app is already installed in the customer’s Splunk app.
