R12.1 Project-2025Sep08
Hostname Correction Settings
There may be a situation that the detected hostname is inconsistent with the actual one. For example, for a Juniper SRX Firewall device, its actual name is “bre1-bor-rt01-n0” and can be parsed by a driver correctly, but its detected hostname is “bre1-bor-rt01”, which will lead to data import incorrection. Especially in the Import Command Only mode, there will not even be any prompt for reminding.
To resolve this issue, you can enter such hostnames (the detected hostname and the actual one) into a table to clarify their mapping relationship for hostname correction.
The system can also automatically fill these hostnames on the Commit tab.
