R12.1 Project-2025Sep08
Hash Tag
Hash Tags are sets of pre-defined tags, such as #device_name or #interface_ip, used to classify incidents and trigger the diagnosis.
A Hash Tag has the following properties:
- Hash Tag Name and Hash Tag Description: The Hash Tag name must be unique and start with #, followed by letters, numbers, and underscore (_).
- Type: The Hash Tags can be manually created by end-users or generated by the system. The system-generated Hash Tags start with a number sign and underscore ‘#_’ to distinguish from the manually created Hash Tags, such as #_device. The Primary Tag of system-generated Hash Tags cannot be modified, but end-users can customize the Associated Tags.
- Primary Tag: A Hash Tag can only have one Primary Tag. Hash Tag entry lookup is based on Primary Tag only.
- Associated Tags: Associated Tags help provide additional information, and a Hash Tag can have multiple Associated Tags. Within each Hash Tag, the name of the Associated Tag must be unique.
- Match Type: (types of match methods)
- String Match: The values of the Hash Tags are matched as strings, which is not case-sensitive.
- Regex Match: The values of the Hash Tags are matched using regular expressions.
- Subnet Match: The values of the Hash Tags are matched as subnets.
Match Method Definition of Primary Tag Value of The Primary Tag Original Data Field in Incident Match Result If Matched Successfully String Match #_Device_name R1 R1 is unreachable #_Device_name (R1) Yes Regex Match #_IP_Address \b\d{1,3}\.\d{1,3}\.\d{1,3}\.\d{1,3}\b 192.168.1.1 cannot be accessed #_IP_Address (192.168.1.1) Yes Subnet Match #_Subnet 192.168.1.0/24 192.168.1.1 cannot be accessed #_Subnet (192.168.1.0/24) Yes
- Whether Enabled: Hash Tags can be enabled or disabled using this option.
- Entry of Hash Tag Value(s): Primary Tags and Associated Tags have corresponding Hash Tag Values listed as entries under each Hash Tag in the Incident Dictionary tab. The Hash Tag Values are generated by the system or manually added by end-users. Those Hash Tag Values can be used to fill in data field of virtual incident type.
