R12.1 Project-2025/11/05
Execution and Baseline Settings
Within the CLI Execution Setting, users can decide the default data source for the CLI command.
Note: If the user explicitly requests to retrieve live data, then the AI Bot will disregard the CLI Execution Setting and retrieve live data. |
Note: - For config commands, the default data source is the current baseline. - For network intent, the default data source is the one defined in the intent’s execution settings |
Within the Baseline Setting, users can specify the data that the executor will use as the baseline for comparison.
- When the ADT Dataset is set as the baseline, it will be the primary option. However, if the ADT Dataset is not selected or has no data available, the current baseline will become the baseline.
- The current baseline can be automatically updated based on the maximum data age.
