Execute Recommended Actions
Recommended Actions refer to pre-defined actions to analyze and troubleshoot a certain network issue. A drill-down action can belong to the template level or device level.
- DVT Level – the action is executed on all devices on a map.
- Device Level – the action is only executed on one device.
The selected recommended actions will be added to a Runbook for users to execute later.
