R12.1 Project-2025/11/05
Disable a Topology Link
To avoid displaying a topology link on a map, you can disable it manually.
Information Note: Only use this function when necessary because it may impact other features, such as extending neighbors, building sites, and rediscovering network devices. The disabled links cannot be diagrammed on any maps even if the topology is rebuilt with retrieved live data.
  2. On the Domain Management page, click Data Accuracy Resolution on the Start Page.
  3. On the Data Accuracy Resolution tab, click Topology Link Manager on the left pane.
  4. In the Topology Link Manager, click the hyperlink in the Total Topology Link column of the topology type.
  5. Select the topology link, and click   to select Disable from the drop-down menu.
    Graphical user interface
    Information Tip: To enable a topology link, remove it from the Disabled Topology Link table and then rebuild the topology type. See Rebuilding Topology for more details.
