R12.1 Project-2025/11/05
Delete a Static Data View
To delete static data views under the Scheduler folder, see Deleting a Static Data View for more details.
  1. In the Data View pane, click Static.
  2. Select the target data view, and click the  to select Delete.
  • Delete for All Devices — delete the data view from the system.
  • Delete for this Map Only — delete the data view for matched devices on this map only, and keep it for others. As a result, this data view can still be browsed in the Data View Manager for the rest of devices.
