Define the Incident Message
You can define the settings to:
- Append a message to the corresponding incident;
- (Optional) Append a recommended Guidebook or Runbook template for interactive troubleshooting.
Besides the text, you can insert data field from the category, built-in fields ({Incident Type}, {source}, {category}, and {triggered time}), and hyperlink into the message.
Define a label and URL before inserting a hyperlink. Besides the manual input, you can insert the data field and custom variable in both fields.
