R12.1-2025July30
Define Basic Settings of Triggered Diagnosis
Click the start menu and select Triggered Automation Manager.
- Click Manual-setup Triggered Diagnosis > Triggered Automation tab and then choose +Add Triggered Diagnosis.
- Define the following basic settings of a triggered diagnosis:
- Name: Enter a name, such as "Check Slow Application".
- Description: Describes the purpose, function or other characteristics of this diagnosis.
- Enable Triggered Diagnosis: Check Enabled checkbox to automatically run the intent if the triggered condition is satisfied. It is enabled by default.
