Dashboard Tab
Triggered Automation is essential to Dashboard functionality, as each TAF-triggered incident is associated with a corresponding triggered intent dashboard (if defined in the Triggered Automation Manager).
To support navigation between Incident and Dashboard and improve accessibility to triggered automation results, the following are the function:
Click the Dashboard tab to preview the Observability dashboard.
Automatically generates an Observability dashboard for each incident; Add all the triggered intent dashboards for this incident into a observability dashboard. This enhancement allows users to get an overview of all incident-related results in one place. This will facilitate you with an at-a-glance overview of all incident-related results in one place.
You can show or hide panes based on your needs during collaboration.
Note : The incident-triggered intent/Observability dashboards will also be deleted if the incident is deleted.
Click + Add Observability Dashboard to select the dashboard from the window.
