Creating a Qapp to Annotate OSPF Routing Design
You can use the built-in functions in the Basic Output node of a Qapp to analyze and display data, such as highlighting a map, drawing a map, defining an alert and exporting a CSV report.
This section introduces how to create a Qapp to highlight devices with OSPF configured and annotate OSPF configurations on the map.
Complete the following two steps:
  1. Use Configuration Command to Obtain OSPF Configuration
  2. Define Output to Highlight Devices with OSPF Configuration
