Logo
R12.1 Project-2025Sep08
Build Base Table via Other Object
Apart from device, interface, path, several Automation Objects can also be used as source for building base table.
The four methods using other object are introduced in this Chapter.
  • Build Base Table via Map & Map Intent
  • Build Base Table via Device Group
  • Build Base Table via Site
  • Build Base Table via Member Intents of Intent Cluster
Build Application Path ADT Via Application Path Build Base Table via Map & Map Intent
