Basic Regular Expressions
Regular expressions are powerful tools for pattern recognition, including both special and ordinary characters.
  • Ordinary characters simply match themselves. For example, A, a, or 0. You can concatenate ordinary characters, so Version matches the string Version.
  • Special characters either stand for classes of ordinary characters or affect how the regular expressions around them are parsed. For example: "|", "(".
The following table lists the frequently used special characters.
CharacterDescription
.Matches any characters except a newline.
^Matches the start of the string or line.
$Matches the end of the string or just before the newline at the end of the string.
*Matches the previous element zero or more times. For example, "ab*" can match "a", "ab", and "abb".
+Matches the previous element one or more times. For example, "be+" can match "been" and "bent".
?Matches the previous element zero or one time. For example, "ab?" can match "a" and "ab".
*?Matches the previous element zero or more times, but as few times as possible. For example, "\d*?\.\d" can match "0", "19.9", and "219.6".
+?Matches the previous element one or more times, but as few times as possible. For example, "se+?" can match "see" and "sea".
??Matches the previous element zero or one time, but as few times as possible. For example, "rai??n" can match "ran" and "rain".
A bracket expression. Matches a single character that is contained within the brackets. For example, [amk] will match "a", "m", or "k".
[a-z] specifies a range which matches any lowercase letter from "a" to "z". These forms can be mixed: [abcx-z] matches "a", "b", "c", "x", "y", or "z", as does [a-cx-z].
[0-5][0-9] will match all two-digit numbers from 00 to 59.
The - character is treated as a literal character if it is the last or the first character within the brackets. For example, [abc-] and [-abc]. But the backslash escapes are not allowed.
|Matches any one element separated by the vertical bar (|) character.
( )Defines a marked sub-expression. The string matched within the parentheses can be recalled later. A marked sub-expression is also called a block or capturing group.
\sMatches any whitespace characters. It is equivalent to the [\t\n\r\f\v] set.
\dMatches any decimal digits. It is equivalent to the [0-9] set.
\wMatches any alphanumeric characters and the underscore. It is equivalent to the [a-zA-Z0-9_] set.
Information Tip: The CLI command outputs always follow certain patterns. You can use the regular expressions to parse the CLI command outputs and retrieve the useful data.
