Set Up Benchmark Task to Auto-Update Aruba Orchestrator Data
Since the discovery only retrieves basic data of your Aruba Orchestrator network, you need to execute a benchmark task to retrieve all data and build all components after the discovery, including topology, visual spaces and data views.
  1. Click the start menu  in the Domain Management page and select Schedule Task.
  2. In the Schedule Discovery/Benchmark tab, click Add  Benchmark Task.
  3. In the Time Settings tab, define the task frequency.
  4. In the Batch Definition tab, perform the following tasks:
    1. Go to the Device Scope tab, check the Select external API servers to retrieve data checkbox and select the Aruba Orchestrator as a source type.
    2. Go to the Buil-in Data tab, and select the Aruba Orchestrator checkbox.
  5. In the Additional Operation After Benchmark tab, select all the checkboxes in the Build Topology and Rebuild Visual Space sections.
  6.  Click Submit.
