Assign a Proxy Server to a Front Server
Each Front Server can only support one Proxy Server. There are two ways to assign the Proxy Server to the Front Server:
Option 1:
  1. Navigate to System Management > Proxy Manager.
  2. Click the downward arrow aside the desired Proxy Server and select Apply to Front Server.
  1. In the Apply to Front Server window, select the desired Front Server.
  2. Click OK to assign the Proxy Server to the Front Server.
    Information Note: Only the Front Servers already registered (the registered status is Yes) are allowed to be assigned with a Proxy Server.
    Information Tip: You can simultaneously apply a Proxy Server to one or more Front Servers.
 Option 2:
  1. Navigate to System Management > Front Server Controllers.
  2. Click the downward arrow aside the desired Front Server in the left pane, and then select Edit.
  3. In the Edit Front Server window, select a Front Server Group and the Proxy for the current Front Server according to your needs.
  1. Click OK to apply the above changes.
