Archiving a Network Change Task
When a change task is completed, you can archive it. Once archived, a change task cannot be edited or deleted anymore. But you can still open and view the historical results of it.
  1. Open the target change management task, click the  icon and select Archive Change from the drop-down menu.
  2. In the Archive dialog, click Archive.
