Adding and Defining a Note Node
The Other Change node provides a note function to remind the change executor of extra operations, such as discovering new devices to the domain, removing devices from the domain and updating modules beyond the change management task.
  1. Point to the Any node and click the  icon.
  2. In the Select Action dialog, select Other Change on the Network Change tab.
  3. Enter the descriptions in the Description field.
  4. Information Tip: You can mark the Other Change node as Completed when it is approved. Then it will be locked and cannot be edited anymore.
