Server-Side Token Authentication
Information Note: From version R12, NetBrain supports OAuth 2.0 and token users accounts are no longer supported. It is recommended to access open API with OAuth 2.0 protocol.
  1. Log in to NetBrain Administrator User Interface with an account that has System Admin privileges.
          https://<NetBrain IP Address or Hostname>/admin.html>
  1. In the NetBrain System Management page, click icon in upper left corner, then User Accounts.
  2. In the User Accounts screen, click Add, then enter the following values:
    Field/SettingValue
    Authentication SourceToken
    Email[email protected]
    First NameAPI
    Last NameAPI
    UsernameAPI
    Allowed IP Address<enter the Jira Cloud IP Address>
    Authorization Configuration for Reset API<Click Re-Generate Auth Token to create a Token>
    User Rights
    Select Standard User –System Management, then:
    • Check all tenants in Tenant Access column
    • Check all domains in Domain Access column and click Assign Privileges in Domain Privileges column to select Power User role.
  1. Click Submit to create the Jira API account.
    Information Note: It is safe to ignore any warning dialog message presented indicating a failure to send a notification email.
  2. With the NetBrain Jira Cloud API user account created, log out of the NetBrain Administrator User Interface.
