View Intent Result on Map
- Enter the NI View Mode and click Output Map to view the intent result on the current map.
Note: If there is no data defined in the intent, the following notification will be displayed and no map will be open. - You can view all the related devices and information (such as intent data view and diagnosis message) on the map.
- Click the diagnosis message to open the Diagnosis Details and Compare pane for more inforamation.
- You can choose to only show alert or success status code in the intent data view.
