View Discovered Devices
Information Note: The results will be updated by Discovery and Benchmark.
  1. Log in to Domain Management Page, and then click Data Accuracy Resolution on the Start Page.
  1. In the Data Accuracy Resolution tab, click All Discovered Devices on the left pane. All discovered devices are listed.
Based on how NetworkBrain retrieved the config files, devices are assigned to 3 categories: Configuration Devices, SNMP Configuration Devices, and Others.
  • CLI Configuration Devices:
    • Fully accessed via CLI indicates that NetworkBrain successfully retrieved the config files via the latest CLI attempt.
    • Latest CLI Configuration Retrieval Failed indicates that NetworkBrain failed to retrieve the config files via the latest CLI attempt.
  • SNMP Configuration Devices: Those devices are categorized by why NetworkBrain can only retrieve SNMP configurations.
  • Others: Devices that NetworkBrain failed to distinguish if they are accessed by CLI or SNMP.
