Logo
View Comparison Result with Golden Baseline
After Applying a Data View Template to a map, you can view the last copy of historical data and Golden Baseline and the live data analysis. When it doesn't match the Golden Baseline Rule, it will be highlighted in red color to alert users.
Apply a Dynamic Data View to View Alert and Drill Down View the Detail Pane for More Data
