Logo
View Comparison Result with Golden Baseline
After Applying a Data View Template to a map, you can view not only the last copy of historical data and Golden Baseline but also the live data analysis. When it doesn't match the Golden Baseline Rule, it will be highlighted in red color to alert users.
Viewing Golden Baseline Analysis Result View Historical Data Analysis in Detail Pane
