Updated Feature/File
Feature/File | Description |
Config File | The configuration file of the device will be updated to the new one. |
One IP Table | The old device name will be updated to the new name. |
GDR | ▪Device: The data of the new device will overwrite the data of the old one. ▪Interface: Keep the interface information of the old device, and delete the information of the new device. |
Share/Private Device Settings | The data of the new device will overwrite the data of the old one. |
Device Group | Old device hostnames in the device group will be updated to the new hostnames. |
Site | Old device hostnames of the site will be updated to the new hostnames. |
MPLS CE List and VRT | Old hostnames of CE devices will be updated to the new hostnames. |
Topology | Rebuild the topology manually to ensure its accuracy after clicking Keep the Latest. |
Map | The old device names will be changed to the new names after updating the map. |
Site Map | The old device names will be changed to the new names after updating the map. |
Default Data View | The default data views of the old and new devices will be deleted, and the rebuilding of the data view will be triggered when the next time the map is open. |
Data View | Old device hostnames in the data view will be updated to the new hostnames. |
Customized Device Icon | If the users customize the device icons for the devices with old hostnames, the correspondence remains unchanged between the customized icons and the devices with new hostnames. |
Context Map | Old hostnames in the context map will be updated with new hostnames. |
Other Features | The data saved in some other features will also be updated. |
