Defining Target Seed
Target Seed defines how to clone the logic defined in the Seed Logic section.
  1. Click Target Seed, then click  + Add Criteria to define the matching criteria for Seed Logic.
Example: If you do not need to filter the seed logic as there is only one seed logic, you can set the condition to be True and select the diagnosis logic Check HSRP Pair Failover.
  1. Click Populate Data to view the matched seed devices and whether this Eigen Group will form a NI.
