Switch Between Map Copies
The master map and its personal copies are listed in the drop-down menu in the upper-left corner of the map. The master map always appears at the top, followed by its personal copies. Each personal copy displays the name of the creator.
Follow the steps below to switch between different personal map copies.
- When a Map is open, click the map name.
- In the drop-down menu, click the personal copy you want to view. Alternatively, click Open in New Tab from the drop-down menu to open the map copy in a new tab.
Tip: In the drop-down menu, you can also see the status of each owner, whether they are logged into the NetworkBrain system. |
Warning: If you try to switch to another copy without saving the current personal copy, a message will prompt you to save it first. ![]() |
