Set Up OAuth 2.0 Client
Google APIs use OAuth 2.0 protocol for authentication and authorization. To allow a client application such as the NetworkBrain System, you need to set up the OAuth consent screen and then create an OAuth 2.0 client. NetworkBrain system will request an access token from the Google Authorization Server, extract the token from the response, and send the token back with the Google API.
