Refresh Subscription License
To avoid account suspension or deactivation of certain advanced features, you must renew the license term when the license expiry date is approaching.
Perform the following steps to refresh your subscription license when a new term is available in your NetworkBrain system:
  2. On the System Management page, select the License tab.
  3. Select the refreshing method based on your situation.
    • Online (recommended) — click Refresh to connect to NetworkBrain License Server and refresh your subscription license immediately.
      Information Note: If your NetworkBrain Web/Web API Server does not have access to the Internet, you can configure a proxy server. Click the  icon at the upper-right corner, select the  check box and enter the required information.
    • Via Email — refresh your subscription license by sending an email to NetBrain. Use this refreshing method only when your NetworkBrain Web API Server cannot access the Internet.
      Information Note: Only use this activation method when your NetworkBrain Web/Web API Server is not allowed to access the Internet.
    1. Click Refresh By Email.
    2. Generate your license file, attach the file to your email and send it to NetBrain Support Team. After receiving your email, the NetBrain team will fill in the license information on NetworkBrain License Server, generate the corresponding update license file, and then send it back to you.
    3. Click Browse to select the updated license file you received from the NetBrain team, then click Update.
