Supported Context Maps of NSX-T Nodes
The following table outlines the available context maps of each NSX-T node.
Node
 Context Maps
NSX-T Virtual Distributed Switch
Two context maps are supported for this node:
  • Layer 2 Neighbors displays the Layer 2 topology to its connected Devices.
  • Layer 3 Neighbors displays the Layer 3 topology to its connected Devices.
NSX-T Manager
NSX-T Tier-0 Gateway
NSX-T Tier-1 Gateway
NSX-T Segment
