Logo
More Actions after Executing Network Intent
You can perform the following actions from the NI result:
  • View Diagnosis Details and Compare Pane
  • Publish Intent for Sharing
  • Display Intent Data Size and Auto Clean Intent Result
Only Map Device with Alert or Success Status Code View Diagnosis Details and Compare Pane
