Manage System Security
Proxy is a common measure for ensuring network security by monitoring network activities and preventing data leakage. The audit log is another security measure provided by the NetworkBrain System. IT devices across your network create logs based on events. Audit logs record the event logs, typically regarding a series of activities or specific activities. You can enable the audit log feature and view the audit log.
This chapter will cover the two measures for ensuring system security:
