Lock/Unlock ADT
To avoid mis-operations on the ADT data, ADT can be locked/unlocked by its creator or other users with corresponding privilege.
For each ADT table, the creator of ADT can turn on the Locking function and set a locking mode (With Password/Without Password). A locked ADT is in View-Only mode and can be edited after entering the password. Lock annotation can be added to provide detailed lock information.
Note: The creator and users with the Shared Resource and File Management privilege can lock an ADT. |
To lock an ADT, follow the steps below:
- Select the target ADT in ADT Manager, then click Lock Settings from the drop-down menu of the ADT.
Note: You can also click the icon to define the lock settings for ADT.
- From the Lock Settings dialog, turn on the Lock function, then define the following settings:
Select a Lock mode:
- With Password (default): Enter and confirm password in the corresponding field.
Users with authorization can open or edit ADT after entering the correct password. Domain admin can operate on a locked ADT without entering a password.
- Without Password: Other users cannot open the ADT and must contact its creator to resolve this issue.
- Type Lock Annotation in the Lock Annotation field to provide lock information for other users.
- Click OK to finish lock settings of ADT.
