Introduction to the Table of Tuning Live Access
FieldDescription
Management IPThe IP address used to access the device in the tuning live access process.
Management InterfaceThe interface used to access the device in the tuning live access process.
Ping
Indicates whether the device can be accessed through the Ping command.
Succeeded — the system successfully accessed the device by ping.
Failed — the system failed in accessing the device by ping.
SNMP ROThe SNMP RO string used to access the device in the tuning process.
SysObjectIDThe system object ID retrieved in the tuning process.
Telnet/SSH
Indicates whether Telnet/SSH is enabled on the device.
Succeeded — Telnet/SSH is enabled on the device.
Failed — Telnet/SSH is not enabled on the device.
Login
Indicates whether the system can log in to the device successfully.
Auto Set Device Settings
Succeeded — the system logged in to the device with one of the Telnet/SSH login credentials in network settings.
Failed — the system cannot log in to the device with any Telnet/SSH login credentials in network settings.
Verify Device Settings:
Succeeded — the system logged in to the device with the username/password pair in shared device settings.
Failed — the system cannot log in to the device with the username/password pair in shared device settings.
Enable
Indicates whether the system can enter the privileged mode of the device successfully.
Auto Set Device Settings:
Succeeded — the system entered the privileged mode of the device with one of the privilege login credentials in network settings.
Failed — the system cannot enter the privileged mode of the device with any privilege login credentials in network settings.
Succeeded — the system entered the privileged mode of the device with the privilege username/password pairs in shared device settings.
Failed — the system cannot enter the privileged mode of the device with one of the privilege username/password pairs in shared device settings.
SNMP Hostname
Indicates whether the hostname retrieved by SNMP is changed.
Unchanged — the hostname retrieved by SNMP is the same as the previous one.
New SNMP hostname — the hostname retrieved by SNMP has been changed.
VendorThe vendor information was retrieved via SNMP.
ModelThe model information was retrieved via SNMP.
Front Server&GroupThe hostname of Front Server or the name of Front Server Group, which is used to access devices during the tuning process.
