Function Modules
NetworkBrain includes the following three add-on function modules:
Information Note: Each module needs to be purchased separately.
  • Application Assurance Module (AAM) provides an integrated solution to manage, monitor, and troubleshoot network applications by combining the application-aware paths with NetworkBrain automation features. Value-added features of AAM include:
    • Application Manager
    • Golden Path
    • Application-Aware Monitor
  • Change Management Module (CM) provides a comprehensive network change management solution to create, approve, deploy and validate complex network changes. Value-added features of CMM include:
    • Change Management Runbook
    • Schedule and Triggered Network Change
  • Preventive Automation (PA) provides the Intent-Based automation solution, including Interactive Automation for troubleshooting, Packaged Intent Automation as Interactive Service, running Automation for Network Assessment, Machine-to-Machine running of Automation.
All functions of AAM and CM require the corresponding module license. However, you may run the automation to a certain limit without a PA license for PA-related functions. The following table summarizes the functions that will be fully or partially restricted for the users without a PA license:
  • There are no restrictions on NI/NIC creation.
  • NI/NIC execution (both triggered via API and interactive execution, including running NI inside API stub) will be metered daily, and there are quotas per Domain.
  • Preventative automation can be set up without the PA license, which includes: 1) Define AM probe; 2) View Trend chart; 3) View PA dashboard.
