Exporting a Network Change Task to Word
You can document a network change task, including definition, device data and node results, in MS Word.
Open the target change management task, click the
icon and select Export to Word from the drop-down menu.
In the Export to Word dialog, define the export settings:
- Modify the document name if necessary.
Specify the location to save the document.
- Select the nodes and results that you want to export.
Note: You need to save the Word document in the NetworkBrain system first, and then you can download it to your PC.
- Click Advanced Setting to modify content. In Advanced Setting, you can modify the exported content and change the Word template.
- Save your modification and Click Export.
Tip: You can include Action Notes and \ Description in the exported Word document. Those two options refer to the following section:
